FAQ - How long should my batteries run for?
posted by: chopper
Posted - 10/28/2006 : 12:34:13
This question is a little hard to answer. It all depends on the different factors involed, so there really is no hard answer.
The average you could expect to recieve from a brand new 12 volt sealed lead acid battery, with a 50 pound kid on pavement, should be a little over an hour. Here comes the it depends part. If the battery is older, then not as long. If the kid is lighter/heaver, then longer/shorter respectively. If it's ridden in grass/uphill/rough surface then shorter run times could be expected.
Re: FAQ - How long should my batteries run for?
posted by: jasncab
Posted - 01/03/2008 : 06:40:13
In this document (look for the lightbulb) they describe how AH work and a lot more:
http://www.boatsafe.com/nauticalknowhow ... attery.htm" onclick="window.open(this.href);return false;
