Battery Mods - Must Do's
posted by: jasncab
Posted - 07/27/2006 : 11:13:14
MUST place a circuit breaker or fuse on the positive side of the power source (batteries). It is recommended that a fuse be put on each battery near the battery on the positive side.
http://www.batteryuniversity.com" onclick="window.open(this.href);return false;
Re: Battery Mods - Must Do's
Insert Image: Image
You can also use that fuse holder, trim the rubber and insert the resetable circuit breaker in it. just make sure to cover or keep it out of the elements to avoid shorts.
free is always better
