Almost done!
Got it lifted and the key switch installed this past weekend... man, I wish I had more time to work on these things!
The kid tested it out and it seems like it's going to hold up very well!
The only stuff left to do is to install the voltmeter (as soon as it arrives from Hong Kong :roll: ), solder the right connector for my charging jack, and make the roll bar and windshield.
my wiring job:
Rear lift:
Front lift:
Result:
EDIT (9/13/2012):
Added PVC windshield, rollbar, and bumper.
Beefed up front bumper mount.
Not as cool looking as the pink foam was, but WAY more durable!
Used the old windshield corners to brace the front bumper/mount. Hard to tell what's going on in the pic, maybe... if you want more detail or a better explanation, let me know and I'll tell you exactly what I did.
You also see how I mounted the PVC stuff to the body... big 'ol anchors! They seem to work well. Beat on 'em pretty good to see if they would come off, shift, or wiggle and they stayed solid. This thing is pretty heavy now, but it can totally be picked up by any of the PVC parts. woot!
Edit: (9/20/2012)
Added the voltmeter, finally!! and gave it a bath and properly covered it in the basement, in case my sister gets any more crazy ideas in her head...
