Mod List (already done):
Blood Red Vinyl Wrap
White Wheels and Grill
Toyota Emblem
Diamond plate rear corners and door sills
Mod Wish List (to be done):
Rubber Tires/Traction Bands
Rear Mounted Spare Tire
Winch and Brush Guard
18V, then...
24V ESC conversion
Working headlights, tail lights, turn signals and under glow.
Some sort of trailer to be towed.
My son needs an upgrade from his little 6 Volt Lightning McQueen quad bike. In steps the Peg Perego Gaucho Grande!
I scored this one, needing a bit of work, for only $40. This is my first Peg Perego, though I know eventually I would like to get a Magica as well.
Here's the well used condition I received it in:
Here's the current list of things I know I need to fix/acquire:
Battery
Hood Hinges
Passenger exhaust cover
Roll bar light
Headlight lens(es)
Pinion Gear (I think, need a diagram to confirm, the steering shaft is not connected to the pinion)
Front Bumper w/fog lights
Front fender flares
Driver rear fender flare
Ignition key
Tool box
Tools
Tail Lights
Red Center hub caps
Driver side mirror
Battery with wires (on the fake motor)
Caps, spark plugs and the spark plug wires on the fake motor.
Bottom side wire cover
Ashtray
Microphone
Gaucho Side Emblems
