CJB POLICE Escalade EXT
Just getting the thread set up here. I'm going to dive into this one this weekend. Using one from my Twin Escalade Haul.
End result should be something like this...
Plans include:
  • Headlights/tail lights/fog lights
    Marker lights/turn signals
    12v w/6v CJB NOS (might as well use my own design finally)
    Possible underglow
    EL-wire dash glow (ala DW)
    floor mats
    and maybe upholstery
Who knows... I might even mount a sub in there somewhere.
Paint:
  • Off-white (or maybe pearl) base coat
    Sparkles (everything MUST have sparkles I guess)
    Clear (maybe)
I'll be using the one that already has the TV and speakers/amp in it. I'll most likely end up flipping the other one after a quick paint job with a close color match. I think the color I used on the brute force will be close.
Since I'm completely changing colors, I'll need to get some new badges and emblems done up. Maybe for the badges I'll just use those self-adhesive chrome letters and numbers - 18V, EXT...
Re: Escalade EXT
I think you might need to lower it too...............might be a cool idea ;) Just thinking outloud.
Re: Escalade EXT
taz11 wrote:I think you might need to lower it too...............might be a cool idea ;) Just thinking outloud.
Good call. I'll look into that.
Re: Escalade EXT
Me too......It's been a long time since I looked under my Esc. I'd love to put in my 2 cents.
DefensiveWound
Re: Escalade EXT
Post by DefensiveWound »
I got a couple cents I could put into the lowering. I've already done it in my head...thats where I do all of my builds first!
hypo21
Re: Escalade EXT
Post by hypo21 »
I wouldnt mind hearing those cents... I like that Idea. I picked one of these up from Taz and was thinking of at least painting and Lighting it. I have a Pearl white real one and woudl liek to try to match the color, so I am interested to see how this turns out CJB
I like where you are going so far...
Racer X
Re: Escalade EXT
Post by Racer X »
I am most interested in seeing what you need to do to get your pearl white color to come out. I will stay tuned.
Racer X
Start your second childhood now,.... mod a Power Wheel
Mustang Project - Eleanor (viewtopic.php?f=19&t=218" onclick="window.open(this.href);return false;)
Mustang Project - Honey Bee (viewtopic.php?f=19&t=1359" onclick="window.open(this.href);return false;)
Re: Escalade EXT
Racer X wrote:I am most interested in seeing what you need to do to get your pearl white color to come out
Yeah... me too. :?
Got it all stripped down last night and did some lighting mock-ups.
Not sure how easy it'd be to lower it. Looks like a LOT of fab work. I'm an electrical guy - not a body guy. :?
Today, I plan on getting out the pressure washer for the body tub and getting everything ready for primer. I haven't been able to find an iridescent pearl color in a spray can (or any other can for that matter) so I may have to go to some sort of specialty automotive shop for it. There's a PPG place by my work. Maybe they'd be able to help. Then I'll have to go to HF and get one of those gravity feed spray guns on sale.
Re: Escalade EXT
I've been pondering this...... I did notice that if you drop the front more than 1 1/2 inches you will have tire conflicts with the door hinge and floorboards.
The rear is easy to do.
Re: Escalade EXT
Here is the rough idea.
CJB lower idea escl.JPG (33.94 KiB) Viewed 22120 times
Stack up some plywood strips to the desired hight, notch one to fit the axle, and squeeze it all together with some long bolts. The gearbox should sit in on the top one. (you might have to trim it down slightly). I would use some fender washers on the bottom of the bolts.
The easiest way for the front would be dropped spindles. I forgot to check last night to see if there is enough clearance on the back of the wheel for that.
DefensiveWound
Re: Escalade EXT
taz11 wrote:Here is the rough idea.
Pretty close to what I was thinking. My plan (sorry, no pic assistance) was to cut out the rear axel tub of a scrapped Escalade that I have laying around. I would trim it down so that all I have left is the very bottom where the axel goes through and the side walls where the gear boxes sit. Risers made of wood blocks would be set down inside the rear tub of the project. To get rid of the gap between the tires and the fenders you would need to drop the back 2.5 inches so 2.5 inch blocks would be used, maybe less depending on tire clearance. Scrapper tub would be placed on top of the blocks and bolted down. Use the gearbox template that is present in the scrapper tub to cut out new gearbox holes higher up in the project tub.
Custom made dropped spindles are the easiest way to go for the front. Any weld shop should be able to do it pretty cheap. You may need to trim the white steering knuckle a little; shave it back maybe a 1/4-1/2 inch.
Hopefully this made sense.
hypo21
Re: Escalade EXT
Post by hypo21 »
Racer X wrote:I am most interested in seeing what you need to do to get your pearl white color to come out. I will stay tuned.
Racer X
ha ha... Me too.. I was hoping Defensive may have some ideas as I have no clue. Not really there yet, need to finish the Gaucho project first... but that may be next.
DefensiveWound
Re: Escalade EXT
Racer X
I do but it would require a detail gun, which you can get a Kolbalt for $40 at Lowes, and a small bottle of water based airbrush paint, $6. Don't know how to get it done just yet without a spray gun. I know there is a pearl spray paint but it looks TOO pearly.
hypo21
Re: Escalade EXT
Post by hypo21 »
I actually do have an automotive spray gun and compressor. but not sure on the cost of paint vs. paint cans.
DefensiveWound
Re: Escalade EXT
hypo21 wrote:I actually do have an automotive spray gun and compressor. but not sure on the cost of paint vs. paint cans.
Always do a test panel first before trying a new paint technique
I recommend using an automotive detail gun which is smaller than a full size spray gun. I prefer a gravity feed gun. Lowes had a two gun set, full size and detail, on their website for about $60. Not bad for a hobby set.
This combo will get it done. Available at any art store that sells airbrush supplies or you can find it easily online and it may be cheaper. Prices reflect an art supply store.
Rule of thumb, just say $6 per bottle. The two bigger bottles, 4011 Reducer and Transparent Base, are 4 fl. oz. and the smaller one, Iridescent Pearl (fine), is 1 fl. oz. You should be able to pearl the whole vehicle with these but I always suggest making more than you need so you don't run out before doing the whole vehicle; it will be hard to make the exact same mixture twice and you will have extra for a later project.
Mix 1 part Reducer to 2 parts Transparent Base to start. Add more Reducer if needed. Add a good squirt of the Iridescent Pearl to the Transparent Base mix. Don't over do the pearl because you can always add more cooats to get the desired amount of pearl.
Lay down your white base coat as normal. I always suggest a flat base coat. Allow the base coat to set up for about 20 minutes. You can either clear coat your base coat now then wet sand or just move onto the next step. If I was doing it then I would clear and wet sand now.
Using the automotive spray gun set up to 25-30 psi, dust a coat of your pearl mixture over the entire car. Dusting is different from doing a coat. You should be considerably further (12 inches or so) from the surface of the car and moving faster, kind of flicking your wrist side to side as you move down the panel. The goal is to avoid concentrated spots of pearl or tiger striping. Create a fog and let it settle on the car. This should set up really fast, maybe a couple of minutes.
If more of a pearl affect is desired, repeat the last step until satisfied. It's best to be able to take the car outside to see it in true daylight, sun light if possible, to determine if it is enough pearl. Use a heat gun to heat set the pearl layer.
Clear as normal. Be sure that you still fall within the re coat windows before clearing.
Using this method keeps you in control of how much pearl affect you end up with. This can be used on any color and even used with masking to create ghost images, such as flames.
Edit- These are water based paints so they are super easy to work with and no real smell to deal with. I airbrush with these in my dining room and clean the airbrush at the sink. Windex is the best way to clean up these paints but it eats away at the chrome in your spray guns over time.
Last edited by DefensiveWound on Fri Apr 01, 2011 1:59 pm, edited 2 times in total.
hypo21
Re: Escalade EXT
Post by hypo21 »
I posted your reply in my other thread. I dont want to thread jack CJB's too badly.
Racer X
Re: Escalade EXT
Post by Racer X »
So did you catch all of that CJB?
Take good notes, and I will see how it turns out. I think what DefensiveWound is saying makes sense and sounds like a solid approach (and therefore I hope it is the one you are going to adopt -- would love to be able to find out the pitfalls on someone else's dime :-) ).
Racer X
Re: Escalade EXT
Do you guys want me to split this topic? Sounds like some good paint info. It might deserve it's own thread.
DefensiveWound
Re: Escalade EXT
taz11 wrote:Do you guys want me to split this topic? Sounds like some good paint info. It might deserve it's own thread.
Hypo21 just posted a thread in Pimp it Out and I just mentioned that it should be moved to Paint and Body. Same content but with more info.
hypo21
Re: Escalade EXT
Post by hypo21 »
Yeah I had the moderators move it already... I forgot we had a paint section on this new forum.
Re: Escalade EXT
Cool....CJB, say the word and I'll remove some "jacking" from this thread.
Re: Escalade EXT
Racer X wrote:So did you catch all of that CJB?
I was at the store buying Arctic White, Clear, and a sparkle top coat while you guys were discussing this. :lol:
SigEp
Re: Escalade EXT
Post by SigEp »
Can't wait to see the paint job. I'm planning to do a similar paint job on our Police Tot Rod. Figured it would be a "flashy" police car. I'm planning to test with Krylon Fusion Textured Shimmer in White this weekend. I'm going to apply it similar to DefensiveWound's mustang.
It's no longer a toy...
12v KT Fire Truck - Lights/Siren ------------------------------- 24v PP Ranger Rzr - Lights
SigEp's Master Project Page ---------------------------------- 18v PW Porsche GT3 - Lights
solo1
Re: Escalade EXT
Post by solo1 »
Anyone ever thought about using something like linear actuators to bag a pw with? Would probably be a pain in the butt to install them but you could raise it up and down off a switch and remote.
Terry Schaffer
6x Usaci, Arspl, Meca. SPL World Champion
SigEp
Re: Escalade EXT
Post by SigEp »
Don't use Krylon Fusion Textured Shimmer in White. It turns out cream colored. I had luck with the following:
I sprayed with Krylon Fusion Gloss White, then did a light dusting with Krylon Silver Glitter Spray. I followed it up with 3 coats of Rustoleum Crystal Clear Enamel. Turned out really nice. You don't see the glitter except up close and it definitely ads sprarkle to the paint in the sun.
Re: Escalade EXT
Okay. She's pretty much done in the paint dept. I used rustoleum plastic primer, then Duplicolor Arctic white and clear with a 'clear effects' glitter coat that doesn't really do anything unless you're in the sun. :?
Still needs some touch-ups, and I totally missed a huge spot that isn't hidden by the seat. Other than that, I'm pretty happy with it.
SigEp
Re: Escalade EXT
Post by SigEp »
Looks excellent. Nice paintjob! I always worry about missing stuff like that when I paint. I came very close a couple of times with our Hurricane. But so far so good...
DefensiveWound
Re: Escalade EXT
Looks great! Wish I could see the sparkle though. I love the white on these Escalades.
Kstorm21
Re: Escalade EXT
Post by Kstorm21 »
Super nice job!!! I was looking for some Pearl White the other day with no luck. I like the white WAY better than the maroon.
Racer X
Re: Escalade EXT
Post by Racer X »
I really like the white too. I am suprised you sprayed clear on it (I thought you were done with clear forever [smile]). I worry about going in such a strong contrasting color when it gets scraped up (the other color screams through on me). My yellow Mustang was once Red and I am sure I will have problems with it soon because I have such a heavy hard shell, that it tends to chip off on edges pretty easy (oh well).
Did you everything get everything straightened out with the DVD player (I seem to recall that it was hooked up wrong or something like that)?
Racer X
Re: Escalade EXT
Thanks! I'm sort of concerned about the color contrast for chips and scrapes, but it should be an easy color to touch up.
I only went with clear because the base color was flat. It worked out well. DW gave me the encouragement. ;)
Here's my schematic in process...
Re: Escalade EXT
Paint looks great CJB! 8-)
This looks like it's gonna be pimpin, with A/V and everything! :P
Re: Escalade EXT
FWIW: I think :? you could eliminate a relay by opening the common 6V and 12V Negative instead of both Positives...?
Re: Escalade EXT
that's my charge lockout. Each + terminal of the battery is isolated during charging. All relays are solely controlled via one key switch.
Re: Escalade EXT
CJB wrote:that's my charge lockout. Each + terminal of the battery is isolated during charging. All relays are solely controlled via one key switch.
OK, that's how I was reading it 8-) - since your Positives need to stay isolated for charging, you need two relays to open both circuits. But couldn't your Negatives stay common for charging, so that only one relay would be needed to lockout the charging circuit?
Re: Escalade EXT
The negatives are separated at the NOS relay.
My -12 is my +6. I plan on charging both at the same time with 2 Schumachers. Not sure if that would create a problem or not. Rather not find out. ;) I got a 'sample' from one of my vendors of 20 SPDT relays, so I'm not concerned in the relay department. I'm swimmin in them. :D
Got the headlights, fog lights and tails installed tonight. OMGD Those lights are bright. I got pics. I'll get them up tomorrow evening.
Re: Escalade EXT
Oh, okay.. I've got time to upload one or two..
Or three...
FWIW... The headlights are the only lights on in the garage...
hypo21
Re: Escalade EXT
Post by hypo21 »
That thing is looking awesome! The white looks great, just like the original picture, and those lights are insane!
Racer X
Re: Escalade EXT
Post by Racer X »
In someone else's thread you said you were shying away from the Super Flux LED's and I can see why. What did your front lights run you? I have three Gaucho's and I think i am going to light them all up this summer and those seem to be the way to go? I wish you had more time in on them so I could see how they are going to hold up.
Racer X
Re: Escalade EXT
The bright ones:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWNX:IT
$5.99 ea w/ free shipping. Came super fast, too.
This will be all I use from now on.
For Ozniums, you're looking at $3.29 ea + shipping. You'd need 3 or 4 ozniums to even come CLOSE to the brightness of these lamps. There's just no comparison cost-wise.
The only down side I've noticed so far, is each lamp pulls about 1/2 amp. Make sure you size your accessory battery accordingly.
QBee
Re: Escalade EXT
Post by QBee »
That paint job is amazing and I'm speechless about the lights! Thanks for the link to the lights, I'm getting my bookmark on now.
Re: Escalade EXT
Took 'er out for the maiden voyage on Saturday. Ran great until a wheel fell off. :oops:
Threaded the axle ends. No more problems.
One strange thing I noticed is when the vehicle was in low speed, there was an issue with the Engaged/Ready LEDs for my timer module - they both came on at the same time. I'm not sure why that is. Works fine in High. I must have some backfeed somewhere, but I'm not sure how that would be since all of my 12v taps are before the throttle. Strange.
gunnarsmama
Re: Escalade EXT
Post by gunnarsmama »
Wow your escalade looks awesome! Great job ( ;
Kstorm21
Re: Escalade EXT
Post by Kstorm21 »
Did you sand anything or just went straight to paint?
Re: Escalade EXT
Why, thank you!
Minor update -
I ordered some cool little lettering for EXT and 18V badges. They came in on Saturday and look pretty cool. I'll try to get them on and a pic posted in the next week or so.
Re: Escalade EXT
Kstorm21 wrote:Did you sand anything or just went straight to paint?
I did A LOT of sanding on this one. Never sanded others before paint, but now I see why it's worth it. The paint turned out really well (aside from the parts I forgot)
daveweber34
Re: Escalade EXT
Post by daveweber34 »
Poor copy of your earlier diagram, I know. So, for the lighting portion of your diagram, what are those two transistor like symbols you have. The circles with three terminal.
In Italy AND in our house WITH our household goods shipment. Yea!
Re: Escalade EXT
switches with leds
daveweber34
Re: Escalade EXT
CJB wrote:switches with leds
Ahhh. So the common ground wire that they are sharing is for the led light in the switch?
Re: Escalade EXT
Yep. ;)
