It started with a free KFX Ninja:
One inebriated evening, I had an idea:
Which became:
And then:
To where it is now:
I still have a long way to go on it! I have some drive system tweaking to do before I can run a full speed 4-wheel test, but smaller tests have been good. For now, I just want to get it moving at 18V to make sure my design actually works and that the kid is happy with it before I look at doing something more involved (like differential steering using a twin 24-volt controller setup ;) ). I'll probably seal the wheels (I'm thinking epoxy resin) and make the front axles next week. Assuming things line up and it works like it's supposed to, this might be ready by Feb.
Question:
Can I use MAPP gas to bend the axle stock? Will that get hot enough or should I just buy the oxy-torch thing from HD?
